:help has anyone had a problem with the shifter not going into park. The shifter stops at the reverse gate and won't go any farther. is this a shifter switch or an internal transmission problem. the cable seems to be free. about 3 years ago i had to change a switch on the trans because it would'nt shift from 1st gear, is this the same situation? anybody had this problem?
Probably the cable at the trans is loose or stretched. Disconnect the cable at the trans lever and see if the lever moves to park- then see if the shift lever moves Ok through the gears- That will tell you what the problem may be.
BE SURE TO USE THE PARKING BRAKE-- AND BLOCK THE WHEELS
