type as in material? more than likely Buna-N nitrile rubber. Regardless, a Buna-N seal would meet the chemical and temperature requirements for that application.Does anyone know what type of o rings are used for the fuel filter? Specifically the small one? Thanks!
Sent from my SM-G930V using Tapatalk
are you lubricating the seals and surfaces before assembly?Thank you for an intelligent reply. I am somehow tearing up the small one.
Yes. I was trying to install the filter upside down.are you lubricating the seals and surfaces before assembly?
Yeah I was trying to do that but it was too much of a pain. I went to Napa, got another kit for 20$If you just need to replace the 1 oring and dont want to buy the whole set you can measure the diameter of the oring and the thickness of the oring and buy one locally or online. There not specialty parts, there just cookie cutter seals made by the millions. Just make sure to get the measurements right and youll be fine.
