1 - 7 of 7 Posts
I am having a problem with the drain plug leaking oil. I have changed out the plug and that didnt work. Anyone else have this problem? It is making a mess of the drive way.
Are the threads on the pan ok if so maybe try a nylon washer
x2...those washers on your drain plug will wear out and allow oil to leak out around the plug.
Dont Try A Nylon Washer, The Copper Washer Will Flatten Out After A Couple Oil Changes, Go To The Dealer And Buy A Few And Replace It Every Oil Change.
or install a Fumoto valve and be done with it.
1 - 7 of 7 Posts
