alrightie well i talked to a diesel mechanic and he said this is normal for the pressure to go this high. its not dangerous... he said it is actually good it is doing this because as your RPMs go up the faster your crank is turning your oil pump which increases the pressure. as long as its not below 15 or even as low as 9 your good. as far as stock air filters go amsoil, banks, or K&N are good. but if you want to step it up a notch i'd go with a cold air intake. some good brands are volant, S&B, amsoil. hope that helps
