The increase in pressure is from the new oils viscosity. The old oil you drained has been thinned by heat and pressure. The viscosity index improvers which are added or "blended" into the base oil have been shredded up and have lost their structure. Pouring in fresh oil replaces these, hence the increase in pressure.
As far as the noise, yes it could be the Dmax tick, but I've noticed some engines are picky with oil filters. My LMM doesn't like certain filters. It's just plain noisier on some. Had a Toyota that was the same way. The AC Delco seems to be a great filter for the Dmax. I run bypass filtration, so the fact that the delco doesn't filter as well as the Mobil 1 is of little concern. I just want a quiet engine!
