1 - 12 of 12 Posts
I have a 05lly duramax and stopped at a light and oil pressure went to 0 and dash said low oil pressure. It did it about a yr ago and stopped, did it yesterday so i parked the truck, started it this morning and was fine now its doing it again. The gauge goes to30 when driving but 0 at idle...... Sending unit, gauge cluster or something else???
hook up a mechanical gauge to see what the pressure is. Did you check the oil to see if it's full and to see if there's fuel in it.
What weight oil do you have-? Has the iol been changed on a schedule-?
Change the oil every 5k with rotella 15-40 since new. just changed it 800 miles ago, level is good and smells fine. No noise when pressure drops to 0 so I cant see how it would be oil pump??
Of course it may just be the sender. Installing a el cheapo temp gauge will tell a lot on how the pump is performing.
I doubt it is the dash gauge, because the light gets triggered separate from the oil gauge.
Discussion Starter · #6 · (Edited)
Ok, will try a mechanical gauge tomorrow. Where exactly is the sensor? Cant find it to save my life! Also if it was oil pump it would do it all the time correct?
it's above the oil filter.
it's on the filter adaptor.
I have the same year truck and the same problem. I took mine into the dealer and they told me it was the ECM. Some how I really dont think that is the problem. When the weekend get here I will be replacing the sending unit because I dont care to fork out $1300 for a new ECM. I also have a thread out there about this same issue and someone posted pictures of where the unit is located. Check it out when you get time.
1 - 12 of 12 Posts
