What should the average oil pressure be for a 6.6 Duramax be?
J jeffrey1948 · Registered Joined Mar 17, 2009 · 18 Posts Discussion Starter · #1 · Feb 28, 2010 Only show this user What should the average oil pressure be for a 6.6 Duramax be?
S sneekee1 · Registered Joined Jan 22, 2010 · 12 Posts #2 · Feb 28, 2010 Only show this user my 04 LB7 idles at 25 psi
D duramaxthis · Registered Joined Nov 15, 2009 · 377 Posts #3 · Mar 1, 2010 Only show this user depends on what truck ya got lb7's run higher pressure then the new ones my lb7 runs 35 idle 60 down the road with oil good and warmed up
viejajefita · Registered Joined Jan 15, 2010 · 1,181 Posts #4 · Mar 1, 2010 Only show this user Had same concerns and was reassured. I was told something like 5ish psi per cylinder from a mechanic that has an 03 dmax with 120k.
