I had a wheel speed sensor go bad which resulted in an ABS light and monthly diagnostics showing ABS trouble. I got a new hub and speed sensor and finally got around to clearing the code but a week later and Onstar still shows the active error code. I have rechecked with my code reader and there is no history or active code shown. Suggestions for REALLY clearing this code? Thanks
Have you asked ONSTAR about this? that's where I would start. I'm assuming your ABS is no longer on in the dash?
They said they don’t know, take it to my dealership. I not longer have the ABS warning light showing. It went off as soon as I replaced the hub and sensor. Thanks
If your ABS light was on, and now off, at least it surely appears that the truck's problem is solved except why ONSTAR still thinks you have a problem. That may be a tough one to solve.
