I have been chasing a very bad transfer case output shaft seal leak for a month or so now. first replaced the seal. it instantly started leaking again within a miles drive down the road. I could get a slight amount of up play out of the yoke at the case so me and a buddy removed the transfer case and replaced the bushing, bearing, seal, and also did the pump rub fix and all looks great. The yoke is tight now and has zero play at all. We also replaced both u-joints on the rear shaft. took it down the road and within a mile it is leaking again pretty good. I can feel a very very slight amount of shimmy going down the road but very faintly and it drives great. just leaks badly and is slinging everywhere. i have inspected the housing for cracks and the cap in the yoke is not leaking. I have read every post i can find on the forums pertaining to this problem. Only thing i have not replaced and last on the list is the yoke itself. It seems fine but i guess i am going to order one of those next too.
Any help or input would be very much appreciated.:help:neener
