So Ive read around and cant find anything about this but seems like it may be a fairly smart idea but the lack of threads on it leads me to believe there is a terrible flaw in this plan that I am missing. Everything ive read about running extra hp through a stock trans seems to say that the shift and down shift that is where a typical limp code is thrown is the shift into overdrive (4-5 or 5-6 on newer models). If that is so than whenever your planning on going WOT wouldn't locking out overdrive until you were up to speed ( like getting onto a freeway or something) and once you got back to cruise speed unlock it and continue with your drive to hopefully eliminate the tranny slip? Also will Tow/ haul mode really help when you plan on dicking around and racing someone every once a while to throw it into tow/haul mode should help prevent slips because it locks the torque converter and if you only use t/h mode for racing then the tranny will already know once you turn on t/h that your about to beat her up a bit? thats what ive concluded from my readings on this site but i would just like a decisive answer and to know if locking out overdrive is a bad idea. thanks!
