1 - 13 of 13 Posts
I'm talking to Dustin right now so I'll probably get my answer from him but I figured I'd post here...
Just randomly checked my codes and I have a P0101 code... Is there something I'n the efi settings I need to change?
And I haven't noticed any performance drops... I dont think... Everything seems fine.. If my maf is rescaled will the truck run better ?
Discussion Starter · #2 ·
bump
still didnt get a answer whats the deal?
Yea I know the code it's a maf volume or something like that.. I'm assuming that I'm pulling more air now that I have the efi and it's throwing my maf off... This didn't happen with the edge... I'm wondering if I need to change my maf settings to something else to stop getting this code and possibly better performance
Could it br that your maf is maybe dirty... I dunno. But im sure Dustin will figure it out
Sent from my Autoguide iPhone app...
Yea I've already cleaned it with maf cleaner
· Banned
Did you change your filter?
No it's pretty clean just checked it last week...
If my maf needs to be rescaled am I going to see any performance change ??
· Premium Member
I just threw a bunch of money at this exact same thing. Threw the p0101 on my top 2 tunes constantly
1. cleaned sensor... still codes
2. New MAF... Still codes
3. Replaced K&N with Volant powercore... NO more codes!
Comparing the 2 intakes, K&N (Amsoil dry filter, not the oiled) has the MAF fairly close to the filter, the volant has it much closer to the turbo.
I have read that Bill's custom intakes puts the MAF closer to turbo so you can use the stock MAF tables. Bills would be much cheaper than the volant... Either way it works for me on all tunes.
we can re-scale you maf if thats the problem
· Been there "done that"
Are you running an aftermarket intake and "oiled type" air filter?. I had one intake.."XDI brand" give me headaches..with this code..it was a mfging issue the maf sensor was not located correctly in the tube. But i belive you can block that code.. I running robs tunes.. he blocked it . I now have the stock airbox in...no problems..
Yea I have a afe cold air and the mouthpiece... I talked to Rob and he explained it pretty well... Not a big deal I just didn't know if I was being robbed of power
1 - 13 of 13 Posts
