1 - 18 of 18 Posts
Comin home lastnight and tromped on the gas in level 3 a couple times and truck went limp and thru codes P0777 and 0700. I couldnt clear with the edge so I took it this morning to tranny guys that did my jr kit. They got the codes to clear and said to back off on power level and see if it throw the codes again. Tranny felt normal after they test drove. I was under the impression that with transgo jr I wouldnt have any probs in level 3. Now its got me worried to put my foot into again. Anybody have same prob or got any insight?
I know the tranny is not shot cause its shifting fine.
Thanks
So if you think Ive done damage, what damage is actually done then. Do you know by experience?
so more to do with age on tranny then to much power? just trying to learn here. One post on this subject says dirt in tranny others say fluid drop, not letting tranny tune itself correctly. thanks for the help
shop said could be bad solenoid like the code read. If it reocurrs i guess Ill know the problem. Ill pick there brain on the clutches as well. Appreciate the help.
· Premium Member
i had the evo and got the same codes and sold it and got efi live with a 150 hp tune and never happened again and ran the quad stealth 2 on 135 beat the shit outta it and never a code pretty common on the edge evo race
· NewEST Spinny Thinggg
you could ask Mike L. I here he is like the best in the nation on an alli just sayin...the edge is causing slip thats what is burning up the clutches like mike said...chances are the efi tunes are built with a big defuel cause you dont have a built tranny where as the edge isn't...that would be my guess
Been driving around town all afternoon in level 2 with no problems. Guess Ill stay out of 3 or off the pedal hard in level 3. Didnt need the transgo jr after all. Oh well, was looking more for mpgs than I was racing. Just got me curious how fast 3 and 4 might have been. Cant imagine what upper levels are like. Never know I guess without built tranny. Thanks again for the info.
i did the same exact thing damn evo race :mad: but i put transgo jr new fluids filters works pretty good but try to stay off the pedal til i can afford or rob a bank for a tranny kit:rof
Discussion Starter · #14 ·
Just hopeing that I havent done much harm for the long haul of the tranny. I only got on it a couple times there in level 3 and then it thru those codes. Havent beat up on it all up till then. If you call that beatin it up. Time will tell I guess.
sooooooooo with all the VENDORS on here noone will say if the tran Jr and Edge will work up to level 4? Brand new truck here so would think clutchs would be good to go with this set up as the brocheres say it will work, appreciate the insight into this matter
Oh well with a transgo i would think it would be fine. I have run several hotter tunes than that and been fine. I did however limp my trans like last week. Im about to hit tyler up and order a transparts stage IV shift kit i think
1 - 18 of 18 Posts
