1 - 9 of 9 Posts
I was driving my truck home todayand got two codes. P0975 and p0700.
Here are the details. Recent trans filters and dex VI within the last 10k miles. Transmission temps usually peeak at 205-210. Outside temp is 95 today.
Coming home, the first 15 miles is highway driving then some stop and go when I go through a couple stop lights/signs. After that I take a dirt road that leads to a creek crossing. The creek is flowing, but only 6 inches deep. Splashed and bounced through the creek and immediately got the cel. The trans was then stuck in 3rd gear. I drove 30 mph up a moderate grade to my house. No water on any connections, and the transmission temp stayed at 205ish like it always does. Got my scanner and cleared the codes. The codes came back after 2 miles. Then I noticed my tcm is loose and floppy on the fan shroud. My drive and access road is gravel, so I thought maybe the bouncing caused the cel. Secures the tcm and took the same drive. No cel. Coincidence or could a solid state component like the tcm be unsettled by bumps enough to throw a code? Anyone ever experienced a p0975? I didn't find any help when I searched because there aren't many p0975 issues out there. Thanks, Travis
Discussion Starter #2
Forgot to add that the truck won't shift out of 3rd at all when the cel comes on. Fluid is full and red. I have wifi live tunes, but I only use sport economy. I also don't drive hard. Trying to get good mpg! :). Thanks for any advice on what to check. I need this truck reliable ASAP. Towing my TT to San Antonio 1 Sep.
Shift solenoid troubles. Here is some info.
P0975 ? Shift solenoid (SS) B -control circuit range/performance ? TroubleCodes.net
Maybe a chafed wire at the TCM since electrical can cause that issue and tightening it up seems to have solved the problem
Thanks. I found that last night and a couple other folks on different sites had the same issue, but didn't have solutions posted.
I relocated the tcm and securely mounted it towards the owning between the dan shroud and battery. Drove it to work and around base, with no issues. Trans temp hasn't gotten past 160* yet and the ambient is 80*. We'll see how she does tonight when I drive home again and it's 95*+. I say this because I think the problem could have been the TCM being loose and getting banged around, but the TCM was also hot to the touch so maybe it overheated. I had to use gloves to work on it. Anyone else experienced an overheated TCM?
Discussion Starter #6
No issues last night. I tried duplicating the conditions as much as possible e.g., driving style, ambient temp, road condition. Maybe the water from the creek splashed on the tcm/wiring? Or maybe the tcm was being jarred too much from not being secured to the fan shroud. I'll report back if the symptoms return.
Discussion Starter #8
You have an open wire either at #71 or # 31 on the TCM.
Sorry, I didn't see your reply. I will check for continuity at those wires. Thank you so much for your help.
I will pin check #71 and 31 at the tcm, but what wires on the trans do they correspond to? Thanks!
Discussion Starter #9
Those pins shot fine. No shorts and good continuity. I took the pan down me did a filter fluid swap while I was shooting wires. I haven't had any issues lately. Hoping the loose TCM was the problem or it was a fluke.
1 - 9 of 9 Posts
