I have a 2001 GMC LB7 with a p1093 code that doesn’t have an engine light, just comes up on my code reader. I am only getting about 11 kpsi of fuel rail pressure. But other than that the truck runs great and smooth. All the balance rates on the injectors are perfect. The cp3 and injectors were replaced 30,000 miles ago. 205,000 miles on the truck right now.
Check intro thread :thumb
Reactions: stevewaclo
Check for collapsing lines under load, or if you have a scanner that can command max rail pressure, do that and see if it's a faulty fpr...I chased a 1093 code for months, and mine ended up being the CP3, however you just replaced yours
