Not sure what the sensor does but truck has initial rough idle and 30mph max speed.
The sensor is located back of the oil fill tube and to the left rear of the thermostat housing looking from the front. Down a bit into the engine well closer to the right head. The connector cable is about 8" long.
I need help identifying the sensor and finding an after market vendor for the chewed cable.
If it's just wire(s), normal stranded electrical cable, you can just splice what you have or cut and install new jumper wire(s).
Reactions: long-time-dmax
