i have the same motor and put 95 hp injectors in it
i think u have 2 have a bigger turbo 2 get more air
u also will want 2 do trany upgrades such as torque converter, kevlar clutch plates, better valvebody,ats co pilot, bigger oil pan, probably other things, thats is far is i got on the trany, and im still having a little problem whe towing heavy loads.i also have a inner-cooler & methanol injection. it all started with wanting 2 use the higher settings on the edge unit. i still have high egts so im thinking about getting a bigger turbo, that, or take the injectors out. im on this web site 2 try and get some input.
if u do want injectors u might want 2 look into 50 or 60hp
