1 - 20 of 43 Posts
Looking to get some 20s with 33s, Does anyone have some pics of their trucks?
Discussion Starter #2
Anyone? Im looking at either Hoss or Novakanes. . .
bump any pics?
this is my old set up... 20's and 305's
i don't know if you'll clear a 33 with just keys i've seen some guys had to jack them all the way to clear 285s
with that setup above, I had to cut the fender, with only keys. My 285's work now and clear by a lot
i run 285s now and im not leveled. only time it rubs is if i hit a bump backing up at full lock
different wheel offsets will affect the fitment too, a 285 on a stock wheel normally clears with the torsion bars up or keys installed, change to an after market wheel with negative offset and it will rub all over.
Discussion Starter #12
I think Im gonna go with the BMF Novakanes 20x9
well there is a bunch of variables if you squash the 285s on stock rims you'd probably get by with slight rubbing but if you put them on a 8-9'' rim as they should be it will rub like a bastard you have to turn the leveling keys up quit a ways and trim the plastic bumper lip
the 285s will work on a 9'' rim but you'll have to jack the leveling key's almost all the way if they make an 8'' go with that it will be less pressure on your torsion bars and a little bit better ride
That is sharp, the silver is very nice with the chrome wheels
thanks i took off the steps today not sure if i like it with or without yet also lowered the front back down like an inch and a half get a little rake to it
Discussion Starter #18
Sharp looking truck wih the chrome
1 - 20 of 43 Posts
