Vehicle Information
VIN: 3GNFK16Z23G241291 Model: CK15906-2003 SUBURBAN 1500 4WD
Service Contract: Yes Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Vehicle has no current record of required field actions.
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: 49WR104G XM Status: Active
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Emission Select Component Ltd Wty 08/30/2003 58 MI 08/30/2011 80,058 MI
Corrosion Limited Warranty 08/30/2003 58 MI 08/30/2009 100,058 MI
Bumper to Bumper Limited Warranty 08/30/2003 58 MI 08/30/2006 36,058 MI
Special Coverage-07187 08/30/2003 58 MI 08/30/2010 80,058 MI
Service Contract
Policy Number: 812578862 Owner: WALLING
Description: GMPP MG 72/100 Deductible Amount: 100.00
Effective Date: 08/30/2003 Expiration Date: 08/30/2009
Effective Odometer: 58 MI Expiration Odometer: 100000 MI
Daily Rental Limit: 30.00
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
10/21/2008 705893 ZSCT----Service Contracts J6400 - Evaporative Emission Canister Purge Solenoid Valve Replacement 88,068 MI
08/20/2007 645092 ZSCT----Service Contracts E9740 - Gear Assembly, Power Steering - Replace 70,533 MI
08/20/2007 645092 ZSCT----Service Contracts Z7902 - 2-DAY COURTESY TRANSPORTATION 70,533 MI
08/20/2007 645092 ZSCT----Service Contracts E7700 - Intermediate Steering Shaft Replacement 70,533 MI
12/05/2006 606968 ZSCT----Service Contracts L1197 - Fuel Level Sensor Replacement 55,578 MI
12/05/2006 606968 ZSCT----Service Contracts C0382 - Rear Side Door Window Regulator Replacement 55,578 MI
12/05/2006 606968 ZSCT----Service Contracts F1440 - Output Shaft Seal Replacement - Right Side 55,578 MI
12/05/2006 606968 ZSCT----Service Contracts K4122 - Transfer Case Shift Control Module Replacement 55,578 MI
12/05/2006 606968 ZSCT----Service Contracts Z7902 - 2-DAY COURTESY TRANSPORTATION 55,578 MI
12/05/2006 606968 ZSCT----Service Contracts K4124 - Transfer Case Two/Four Wheel Drive Actuator Position Sensor Replacement 55,578 MI
05/26/2005 524352 ZREG----Regular Vehicle Transaction D2220 - Case, Heater - Replace 25,531 MI
05/26/2005 524352 ZREG----Regular Vehicle Transaction E7700 - Intermediate Steering Shaft Replacement 25,531 MI
05/26/2005 524352 ZREG----Regular Vehicle Transaction L1200 - Fuel Tank Fuel Pump Module Replacement 25,531 MI
05/26/2005 524352 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 25,531 MI
03/31/2004 465590 ZREG----Regular Vehicle Transaction B1791 - Rear Window Washer Nozzle Replacement 5,103 MI
03/31/2004 465590 ZREG----Regular Vehicle Transaction C4011 - Panel, Quarter Trim - Left Rear - R&R Or Replace 5,103 MI
02/26/2003 A41291 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
BUILD
Vehicle Information
Vehicle Build
Model: CK15906-2003 SUBURBAN 1500 4WD Order Number: FZSJV5
Gross Vehicle Weight: 3,269 Build Date: 02/26/2003
Build Plant: G
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
1SM - SUBURBAN LT PREFERRED EQUIPMENT GROUP: * 6 WAY POWER DIVER BUCKET SEAT * 1ST AND 2ND ROW LEATHER SEATING SURFACES * PWR FOLD AND ADJUST HEATED OUTSIDE MIRROR WITH TURN SIG AND DRIVER SIDE AUTO DIMMING * ELECTRONIC CLIMATE CONTROL 1SZ - PREFERRED EQUIPMENT SAVINGS
50U - SUMMIT WHITE/LT PEWTER MET 6XL - COMP FRT LH COMPUTER SEL SUSP
7XL - COMP FRT RH COMPUTER SEL SUSP 922 - GRAY TRIM
92I - GRAY INTERIOR TRIM A31 - POWER WINDOWS
AG1 - SIX-WAY POWER DRIVER SEAT AG2 - 6-WAY POWER DRIVER & PASS SEATS
AJ1 - DEEP TINTED GLASS AJ7 - AIR BAG SIDE IMPACT DRIVER AND RIGHT FRONT PASSENGER
AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT FRT PASS AL4 - 2ND ROW BUCKET SEATS
AN3 - FRONT BUCKETS WITH POWER ADJ. AP9 - CARGO CONVENIENCE NET
AS3 - THIRD ROW BENCH SEAT AU0 - KEYLESS REMOTE DOOR LOCK
AXP - MPV VIN IDENT POSITION B30 - WHEELHOUSING & FLOOR CARPETING
B39 - COLOR KEYED FLOOR MATS/ CARPETED B58 - COLOR-KEYED FLOOR MATS, CARPETED
B71 - WHEEL OPENING FLARES B85 - BRIGHT BODY SIDE MOLDINGS
BVE - ASSIST STEPS C25 - REAR WINDOW WIPER & WASHER
C36 - REAR HEATER C49 - ELECTRIC REAR WINDOW DEFOGGER
C5Z - 7,200 LB GVW RATING C69 - AIR CONDITIONING-FRONT & REAR
CJ2 - AIR CONDITIONING AUTOMATIC DUAL ZONE D07 - CUSTOM FRONT FLOOR CONSOLE
DF5 - ISRV MIRROR W/COMPASS & TEMP DH2 - LIGHTED LH & RH VISOR MIRRORS
DK7 - INTERIOR CUSTOM ROOF CONSOLE DL3 - OSRV MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ, HEAT, TURN SIGNAL
DT4 - ASHTRAY MUFFIN E52 - LIFTGATE/LIFTGLASS
EVA - EVAP EMISSION REQUIREMENT FE9 - FEDERAL/NY/VT EMISSIONS
FK2 - TORSION BAR SPRING ADJUSTMENT FK3 - TORSION BAR SPRING ADJUSTMENT
G65 - LEVEL CONTROL MAN,SELF ADJUSTIN G80 - LOCKING DIFFERENTIAL-REAR AXLE
GT4 - REAR AXLE - 3.73 RATIO JC4 - 4 WHEEL POWER DISC BRAKES
JF4 - POWER ADJUSTABLE PEDALS K34 - CRUISE CONTROL
KG3 - 145 AMP ALTERNATOR KNP - HD AUX TRANSMISSION COOLING SYS
KUP - THROTTLE CONTROL ELECTRONIC L59 - VORTEC 5300 V8 FLEX FUEL ENGINE
M30 - 4-SPD AUTOMATIC TRANSMISSION MSL - SILAO, MEXICO PLANT
NF2 - FEDERAL EMISSION SYSTEM NP5 - LEATHER WRAPPED STEERING WHEEL
NP8 - AUTOTRAC ACTIVE TRANSFER CASE NZZ - OFF ROAD - SKID PLATES
PDC - CARGO PACKAGE INCLUDES: * CARGO NET * LUGGAGE RACK CROSS BARS * CARGO SHADE * CARGO AREA MAT PDH - DRIVER CONVENIENCE PACK INCL: * HOMELINK UNIVERSAL TRANSMIT. * POWER ADJUSTABLE PEDALS * STEERING WHEEL MOUNTED CNTRLS
PDM - WHEEL FLARES & SKID PLATES PDZ - TRAILERING PACKAGE INCLUDES: * TRAILERING EQUIPMENT * TRANSMISSION OIL COOLER
PF4 - CAST ALUMINUM WHEELS QMJ - P265/70R16 BW TIRES
R7D - OCTOBER RE-PACKAGE R9U - GM ACCESS - AUTOBOOK IDENTIFIER
RYJ - RETRACTABLE CARGO AREA COVER SAF - SPARE TIRE LOCK
SLM - STOCK ORDERS SLT - EQUIP CHEV 'LT' SALES PKG
T96 - FRONT FOG LAMPS U2K - XM SATELLITE RADIO-100 CHANNELS OF COAST TO COAST DIGITAL SOUND (SUBSCRIPTION CHARGES EXTRA)
UC6 - AM/FM RADIO,RDS,6 DISC CHANGER, AUTO TONE CONTROL, AND ETR (REPLACES STD/OPT PKG RADIO) UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1 YR SAFE & SOUND PLAN AND STEERING WHEEL CONTROLS
UG1 - HOMELINK UK3 - REDUNDANT RADIO CONTROLS
UK6 - REAR SEAT AUDIO CONTROLS UQ7 - BOSE SPEAKER SYSTEM
V1K - BAR LUGGAGE CARRIER V22 - DELUXE FRONT APPEARANCE PKG.
V54 - BLACK ROOF LUGGAGE CARRIER V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
V76 - RECOVERY HOOKS VB3 - CHROME REAR STEP BUMPER
VG3 - FRONT DELUXE CHROMED BUMPER VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VXS - COMPLETE VEHICLE LABEL X88 - CHEVROLET CONVERSION
XMJ - TIRE FRONT P265/70R16-111S BW YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD6 - BASE REAR SPRING YE9 - SILVERADO
YMJ - TIRE REAR P265/70R16-111S BW Z82 - HEAVY DUTY TRAILERING EQUIPMENT
ZM9 - CONVENIENCE PACKAGE ZMJ - SPARE TIRE P265/70R16-111S BW
ZW7 - PREMIUM RIDE SUSPENSION ZY1 - SOLID PAINT
