Can anybody help me out with the procedure of replacing the rear rotors on 2017 Silverado 3500 dually cab & chassis model ?
I am having a issue on removing the driver side axle. It won’t come off like it’s catching something from the inside of the housing. I haven’t done the passenger side yet. Not sure if I am missing something.
This is my first time doing rotors on a dually
Thanks
Sounds like the parking brake pads are expanded into a bit of a groove on the inside of the drum. Make sure the parking brake is completely released and try again. If that doesn't work, you may have too adjust the pads in so you can get the drum/rotor off.
Sorry I should of explain it better. The axle comes out half way out and then it gets stuck. Idk if I should used a hammer and force it out. Scare I might damage something.
