With reading here about DEF fluid freezing at 12'F or -6'C, I have to ask; If I plug in my 2022 truck, will this turn on a Block Heater or the DEF Tank Heater?
Also another question, if the DEF Tank heater is not plugged in, does the truck turn it on while I Drive?
Another question of the day, How do the DEF line leading from the tank to Injector defrost? Especially while driving? Seeing they are exposed to the elements, and when you drive you add wind chill to the equation, do these line even defrost?
I see the Injector defrosting and a couple inches of the connecting hose due to the exhaust heat while driving, but the rest of the lines don't. What do the guys in Alaska do? Wrap the lines in plumbing insulation? I would think once I get out of the garage, the lines would instantly freeze in -20 to -40'F.
Ok I will admit these are shower thoughts, but they are still valid questions...
