1 - 15 of 15 Posts
Fort St John BC via AK
Ok . can anyone tell me what does plugging the resonator on my LMM do?
Some say it makes the turbo louder. Other's say it spools faster.
I plugged mine and noticed no real differences at all. Just be sure and use either lock tight or lock nuts or something in lieu of the wing nut that comes w/ the plug. The wing nut could back off and be fed thru your turbo.
yeah i thought so. variable vane turbos don't whine so much as they sound like an air compressor dumping pressure.
Administrator
I used a rubber cap that fits the outside (not one of the plugs with wingnuts) and a hose clamp. No worries about things coming loose & ending up in the turbo.
Took mine out. Figured it wasn't worth the risk. Ill send it to ya for shipping.
Hang it!...Fire!
mine has been standing fast for awhile now.
I bought one of the pcv caps to use. Put it in and could tell absolutely no difference. Unless your resonator is cracked, I wouldn't even bother.
thanks guys .saves me about three bucks for nothin lol .guess if you want to here turbo whine .go with compound turbos .
for 3 bucks and more air in the turbo faster why not ?
u gotta thing a straight tube with out any huge pockets off to the side is gotta help air flow to the turbo better might not be much but it is better,
those stupid boxes should never been there anyways lol
I agree. if i was looking for .2 millibars of flow reduction on a 5 sec quarter mile ? sure it may be just enough to win why not. but for what little gain its not worth the risk assessment. that is sucking a foreign material into my turbo.
Administrator
if you get the rubber cap that is held on by a hose clamp...there is no risk of sucking anything in. (it all goes on the outside of the intake tube)
I did mine because my resonator wouldnt stay put on my AFE intake tube.
the turbo is sucking in pretty hard, that rubber with heat and time will get old and crack ,
u can buy the mmp kodiak mouth piece and have no hole.
the spin in lock cap will never come out tho from homedepot ,
or just buy a new piece for 3 bucks once a year and thro it on every other oil change its not hard, lol for the peeps worried bout sucking chit in there turbo ,
Administrator
They didnt have the right size spin in lock at my home depot here...so I got the rubber cap. I highly doubt mine will crack...it is pretty thick rubber.
the one I bought was also from the home depot. I bet the rubber is probly at least a quarter inch thick. I'm not using mine but I'll keep it around just in case the resonator ever cracks.
aligator performance sells a special plug. Thats what I bought. I wanted to do it right with no risk. It makes the turbo louder on the intake side. I thought it make it a noticable amount louder. Sounds like you build more boost, but you dont. It 30 bucks for the billet piece with an o ring on it. If you order something from alligator I would throw it in.
1 - 15 of 15 Posts
