Starting to run into issues with my steering. I am replacing everything, gear box, pump, lines(the feed line leaks) and I'm upgrading to a 2011 hydro boost and will probably replace the master cylinder at same time and flush break system as it's about time to do so.
Question is as far as power steering pump and gear box. I'm pushing 35s and with heavy wheeling and deep ruts who should I upgrade to as far as stronger and has a good reputation.
I was looking at psc pump and redhead gear box but then I saw the psc gear box. Is the nearly $500 price difference that much better for the gear box? Or does red head make a good quality upgrade that is stronger than oem. I also don't want to change the ratio. Open to other opinions.
