Hey Folks,
A friend of mine has a 2013 LML 3500 4x4. Over the last 3 years, we've probably changed 9 to 12 power steering hoses on his truck. All pressure hoses. About 2/3 of the time it is the hose from the box to the hydroboost. The other 1/3 of the time it's from the booster to the box. In September 2021 he decided he'd had enough. We changed out the pump (suspected the pump and or pressure relief may be the culprit) and the brake booster, put 2 new lines on (all ACDELCO/GM stuff) and bled out as much of the old oil as we could and filled with new. Well, in February another line let go. It was replaced. Halfway through March, it failed again. This last week, he had two hydraulic hoses made that have a >5000psi working rating and a burst rating of >20,000psi. After installing the hoses and purging the system, the truck doesn't seem to want to steer unless over 1000rpm. The brakes are also... unimpressive. The steering system is primed with DEXRON-VI As it stands the truck is parked. Suspected the fluid might be a problem. But, ATF is an excellent hydraulic fluid and is no stranger to power steering systems. Then figured the hoses that were custom made were too small. He doesn't suspect they are. They're 3/8 hoses, just like the GM lines. So, we figure air might be in the system. Does anyone else have any idea as to what else it could be?
Also, does anyone know why the hell this truck would be popping hoses all the time anyway? All sorts of fluids have been tried. Standard power steering, AC cold climate, ATF, you name it. Doesn't seem to be fluid related in that regard. The hoses have popped in the middle of summer and the middle of winter, so it doesn't seem to be pressure related. Truck has 300,000km/185,000 miles.
And..
Yes, the hoses are hooked up properly on the booster, and the hoses are hooked up in the right spot on the box (port from booster and the cooler port.)
Thanks a ton!
And..
Thanks a ton!
