1 - 9 of 9 Posts
I have a 2013 crew cab LTZ. My passenger side window just stopped working. I pulled the CB 1 fuse and it's good. Cant find anything online. Figured I might try here thanks for any info
Cool thanks for the reply I will try that. I probably should mentioned that It wont down from either the driver side or passenger side. not sure if that would matter or not
make sure the window lock switch isn't on.
I had the same problem on a 2013 ext cab 3500 and it turned out to be the window switch panel on the drivers door. Got a new GM part on Amazon and took 15 minutes to change. Problem solved
2012 3500 hd srw
Agree with above. Last two trucks same thing. Change drivers side. Fixed problems.
I know this is an older message, but in case this helps anyone, many times there is just corrosion on the board under the rocker switches. You can take the board out and use a pencil eraser on the gold contacts to remove the corrosion. Worked like a charm for my truck.
1 - 9 of 9 Posts
