1 - 7 of 7 Posts
Hi,
Do you guys think it is ok to use the Predator Programmer on a stock LB7 if I just use the tow tune. I would like to get one and try it on the first 2 settings but not sure if it will hurt my truck or not. Thanks for your help.
Edit/Delete Message
Hi, I'm Earth. Have we met?
Yeah you should be fine on the lower settings, you could even run the higher settings just keep into the throttle during a 4/5 up or down shift!!
Isn't Predator a module, not a programmer? I almost bought one, becasue my friend swears by them...and he sells them too!
But I found a used VA and am happy with it.
Your truck is going to be...SILLY FAST with the Predator!!!
There is a Dr. Performance Predator - module, and then there is the Diablosport Predator - programmer. They are from different companies.
Dont wanna sound too dumb but why keep into the throttle? I would think that we would need to avoid full throttle shifts from 4 to 5. What am I missing?
1 - 7 of 7 Posts
