1 - 11 of 11 Posts
How much of a gain would you earn with them? Comparison to stock LLY pipes and manifold. Anybody offer anything better? Gotta spool a GT42 T6 88mm
yep yep...
hows that truck run like it is? im fixin to slap a turbo and probly another set of heads on mine again.
Laggy for a DD, boost gauge usually sits on 0. I think Up-pipes and manifolds are gonna be my best bet on better spooling without swapping pedistals.
yep yep...
Mines pretty laggy too with a stock turbo, maybe I should do up pipes and manifolds before the turbo.
Depends on turbo, if you want another VGT like a cheetah I do the turbo, if you were planning on doing a big turbo I would do up-pipes and minifolds first
Its just a worktruck
I don't know if they will help that much. That's a pretty big exhaust side. What made you get that turbo as a single? Its usually run as the atmospheric in compound setups.
Discussion Starter #7
Built the motor the same time Buck Spruill got his compounds so I used he old turbo and got rid of the tiny cheetah I was going to run on there and thought I was going to use the truck as just a race truck and spray alot of N2O to spool it but since its in a nice four door and I sold my DD for the motor build haha it became my bad to the bone DD the doesnt spool until atleast 55mph
Built the motor the same time Buck Spruill got his compounds so I used he old turbo and got rid of the tiny cheetah I was going to run on there and thought I was going to use the truck as just a race truck and spray alot of N2O to spool it but since its in a nice four door and I sold my DD for the motor build haha it became my bad to the bone DD the (turbo) doesnt spool until at least 55mph
lol. I bet.
If you want my honest opinion, I would sell that turbo and get a nice 75mm T4. When properly set-up they are capable of close to 1000 on fuel and can be very DD friendly. I don't know if you could just swap exhaust housings on the GT42 either. The turbine wheel might be too big to fit in a T4. You'd have to ask someone more familiar with Garrett turbos.
Discussion Starter #10
yeah Ive considered that actually but its hard to part and I think with even more work on the exhaust side without changing housing it would be fine I just hate pressing the pedal a little and leave a cloud behind me, and its just cool to have the turbo buck ran his first 9's on. Or Ill just give it a little bit of spray off of each redlight :thumb
Better get a 50# bottle!
1 - 11 of 11 Posts
