1 - 10 of 10 Posts
when i get a leveling kit and about 33in tires should i get a programmer to reset the computer? wont the larger tires throw off the speedometer or something? it will give me some hp and better gas mileage right?
Yes, a tuner like the Diablosport Predator will correct for larger tires, which will bring your speedo and odo back to correct. This will also help your shifting a little.
The extra power CAN help produce better fuel mileage by using a more desirable timing and better fuel pressure, but often times this is offset by the shear fun of having that power available. Bottom line, if you baby it, mileage will come up, if you hammer it, mileage will stay the same or slightly drop. Takes fuel to make power.
Bang for the buck, the Diablosport is about the best bet.
Diesel Addict
i agree with Diesalnut.also look at the PPE tuners but the best for the buck is the Diablo.
and is this a programer that i can plug in and do all of the stuff myself or should i take it to a mechanic becuase i have no experience with something like this.
Diesel Addict
yep thats all you do but the one thing you wanna watch is don't do anything that wold make it try and comnicate to the computer such as opening and closing the doors and having the radio going and watch that no one sits in the passenger site since they have a air bag sensor in the seat..
is it done with the engine off or running?
Diesel Addict
all programmers are tuned with the engined turned off but the key in on postion...
Yes, and you may have to pull 3 fuses. Kinda a nusines, but life with a GM. You will have to pull the fuse for the info center, radio, and radio amp if memory serves. . . . . .
And like Tyrboyz said, just let the truck be while it tunes. Doesn't take but about 5-7 minutes I think.
1 - 10 of 10 Posts
