Hello Everyone!
New to the forum, and just bought my first diesel a few months ago. Still haven't quite figured out everything that has been done to it yet, but slowly figuring it out as I go and learning all about diesels in the meantime. The P/O knew absolutely nothing about it, and from what I've seen so far knew nothing about vehicles whatsoever.
Apart from the numerous problems that it came with, (seized calipers a week after I bought it, dreaded P003A code comes in every few days, and plenty of other things) I was doing the transmission cooler lines and when I pulled the intercooler tube out to get at the rad fittings, I happened to look down the tube. There was a lot of oil in there. I don't mean it was coated on the tube, but like an actual puddle of brown oil/water mix looking gunk sitting on the bottom (see pictures). After heavily researching the PCV reroute, it looks like most people report just a film of oil on the pipe and maybe some drips in there, mostly on the drivers side right off the turbo. I haven't seen anything quite like this. The pipe coming from the turbo is coated in oil which I'm guessing is from the PCV, but is there some other issue going on here? Will cleaning it out and doing the PCV reroute solve this? Tell me what you think!
2006 LBZ, 260000 KM, 4" exhaust. EGR has not been deleted.
