1 - 20 of 30 Posts
I have a 2001 Silverado LB7 that doesn't want to keep the anti-freeze down. For some reason when I top it off (because that annoying light will stay on) it will hold it for a little while (usually no more than 5 miles) and then pukes some of it out causing the low coolant light to come back on. I have removed the thermostats and replaced the overflow cap but still no luck. I do have plans on replacing the radiator but I don't think that is going to stop it either. Does anyone have any ideas? I haven't put a pressure gage on it yet to see what it is pressuring up to but I know it's atleast 15 psi and it will hold the pressure for a long time after the truck has been shut off. Any help would be greatly appreciated.:help
Administrator
maybe a headgasket or injector cup?
I thought about that but my water and oil are not mixing and the injectors haven't been touched. Could it possibly be anything else?
injector cups can crack and sometimes leak compression into the coolant and it will cause it to over pressure and blow coolant out..
Administrator
you can have a bad headgasket and not mix coolant and oil on a diesel.
all depends on where the hg blow to i guess
Discussion Starter #9
I guess I may need to check my hg's and see what's up. I'm not sure about the upper hose being hard in the morning, haven't checked that one yet.
Administrator
if it is hard in the morning...it is really pointing at HGs.
just do a coolant pressure check and that should give u idea ....
Administrator
Personally if I had a bad HG I would probably change my injectors and cups at the same time if I could scrounge up the money.
x2 while your already that deep in the motor
Administrator
dont you have to pull the injectors out of the head anyway when pulling the head? I would think a bad cup would come out with the injector.
yes u have to pull the injector before u pull the head well u dont have to but its easyer
1 - 20 of 30 Posts
