does this not involve anything like the merchant one does?I did it with a used 50k mile t-case I bought after the previous owner ran the original t-case dry. I got the inexpensive piece from IdahoRob, its a solid steel piece that drops in place after you open up the case. To me it looks like a bulletproof fix for the pump rub. Very easy to do.
It accomplishes the same thing, the merchant kit uses a different designed pump housing that you swap. Its an easy swap as well.does this not involve anything like the merchant one does?
They are both very simple once you have the case open Kyle. One is a drop in piece over the pump housing and the other you just take a few bolts out and swap in the new pump housing.hmm..this makes me wonder..robs seems easier i just set it in there andi m good to go? merchants seems like there is more work
