1 - 7 of 7 Posts
Hey I ordered the pump rub kit from you guys a while back and turns out my truck has already been done. My question is will this work on a 2001 duramax/allison? Mine is an 02. Thanks.
All 01-07 classic t case are the same. Only diffrences are between manual and pus button shift t cases
Sent from my SPH-D700 using AutoGuide App
I'm That Guy...
All 01-09 t case are the same. Only diffrences are between manual and pus button shift t cases
Are you sure, I was told you don't need the pump rub kit for 09.
Banned
^This. IIRC NBS trucks had the issue fixed, so wouldn't it be 07.5+ don't need it??
I it was fixed in 07.5. it also seems to be happening a lot less on 06+ trucks too. 07.5+ are diffrent t cases though
Sent from my SPH-D700 using AutoGuide.com App
1 - 7 of 7 Posts
