I just pulled my transfer case out tonight to do the pump rub fix while the transmission is getting overhauled. The small piece of steel that sits in the rear half of the case (the spot where the case usually wears through), is broken in 2 pieces. Does that need to be replaced before I install the upgrade kit, or should I be fine without that small steel piece in there at all?
So there shouldn't be any longterm problem if that clip isn't there at all? I may just change it if I can locate one tomorrow from the dealer, but if I can't, I just wanted to make sure I would be OK without it.
Great. Thanks for the info.
