1 - 18 of 18 Posts
I have a V-6 4.3 Vortec in the 1997 Chevy Cheyenne pickup truck, but im wanting to put a 6.6 L Duramax in. I realize that I will also have to change the transmission and wiring harness as well. Has anyone attempted to do this?
Go buy a duramax!! It would be a lot less of a headache and probably come out about the same price as doing a swap! You have to think, the tranny, the rear axle, engine bay modifications, and more to make the drive train fit!
Would cost big bucks and take several months-- and you would also need technical advice on many components. As stated-- buy what you want.
If your Just doing it to repalce a weak old motor and want something cool. Its going to cost you the same as if you were to go buy a LB7.
When it goes in show car, drag car, non daily. and you have the extra money...... Go for it
plus why do you need that much power on that weak of a chassis?
Hang it!...Fire!
yea if you want a diesel in that body get a 4bt but if you want a duramax buy a duramax
Administrator
JohnO on the forum completed this swap in a older Silverado.
96 gmc an yes it isnt that bad i jus did everything different than the fellas i was gettin help from. pm me your email an ill get ya set up with sum pics an problems an stuff i ran into
What are you going to be using it for?
good for you john, 88-98 trucks are the best looking trucks on the road imo. just curious, why different than the advice you were getting? bad advice, different circumstances or other?
Discussion Starter · #14 ·
I'm planning on pulling a goose neck trailer. I will be hauling a 1972 Monte Carlo with a 454 in it. That's the reason why I was thinking about putting a Duramax in my 1997 pickup.
If you really want to do it-- buy a "Total", and install everything from that, to your truck. Engine, harness, computers, trans, rear axle.
In the old days, you could just fit it in, and hook up a few wires and hoses, and it would run-- not easy anymore.
To the op- What year engine/trans are you plannin to use with the swap?I used an lb7 so you could pretty much copy mine but if lly+ some things might not work but most should
Administrator
I like the idea of finding a totaled truck, you will find from talking to John O though that you run into other BCM related issues. With some persistence you can overcome these though.
1 - 18 of 18 Posts
