1 - 2 of 2 Posts
Was at the gas station and had the ignition on, the first click with the key so the radio would run while I filled up. Started the truck and had a battery light on. Ez-lynk says the battery is 14.6v, checked voltage at the battery and it's 14.81v. Battery light won't go out, is the alternator going bad? I just had both batteries check 2 months ago and they passed with flying colors...
Discussion Starter #2
Follow-up... a battery that previously tested good was bad. Make sure if you have two batteries that you disconnect one before they try to test them. I was told that both we’re good.
1 - 2 of 2 Posts
