Doing my head gaskets soon and will have the truck torn apart. also time to change fuel filter, reading too much info on here. I have only used a WIX filter. I can not recall the price, but I think it was rather spendy. If I plan on owning my truck for the forseeable future is it worth it to puchase a Nicktane adapter and run CAT filters? As I understand there is no water separator in the filter, it is not needed as sworn by many on this site.
Never had a water in fuel line message come up expect when I first purchased the truck (used), but I was already changing it anyway.
not sure what micron size the WIX is or what the CAT is.
hook me up with some knowledge please. I just rebuilt the housing last April after I got EFI live.
How often are you changing fuel filters?
P553203 is the Donaldson number, Rated at 3 microns.
Cat 1R-0750 is 2 micron.
Wix stock replacement I think is around 10 micron.
just bought the nicktane setup with filter and spacer from his site....
used promo code madeinusa and saved $34. :) every bit helps! wooowooo
