1 - 8 of 8 Posts
Check this out - Design Engineering, Inc. has released a new line of Chemical Additives including Radiator Relief for DIESELS!
Retails for $9.97 per 16 oz. bottle
PRODUCT DESCRIPTION
Radiator Relief‚Ñ¢ for Diesels supercharges your radiator by transferring heat more efficiently through the radiator. Similar to the original formula this proven coolant additive will reduce your operating temperature up to 30¬?F and reduce engine wear which occurs during extreme heat. NEW Radiator Relief‚Ñ¢ for Diesels is also formulated with a corrosion inhibitor that reduces mineral deposits and is the first additive that maintains pH levels that otherwise fluctuate over time resulting in core damage.
• 30 degrees lower operating temperature
• 50% quicker warm up
• No mixing required; ust add to radiator
• Compatible with water and all anti-freeze mixtures
• Safe with all alloys
• 100% Biodegradable, Non-Corrosive and Non-Toxic
• For use in all water cooled engines
For more information visit www.DesignEngineering.com
that is cool might have to pick up some, I wonder if you have to drain your radiator alil to fit it in
Nope, you can just add it right to your cooling system, but DEI does include a Radiator Relief FLUSH that you can use to break up any mineral deposits or existing corrosion and rinse it with distilled water for best results.
well ya but say your radiater is filled to the cap with coolant, how are you going to add this?
1 - 8 of 8 Posts
