I have the factory elevated idle turned on, this morning before leaving for work i started the truck to warm up and it idled normally with no elevated idle active ECT was about 55 and Intake air temp was 40. After leaving and driving about 3 miles the truck was at 143 ECT and Intake air temp at 43. When i got to my destination and parked the truck, the elevated idle kicked if for about 5 seconds the kicked right back off and idled normally. This is the first time this truck has done this since i've owned it. should i be concerned or be looking for any issues? i appreciate the insight in advance guys! Also all temp readings were directly from the Edge Insight
Former GM Tech and parts
I wouldn't worry anything about it. Seems like here in the last couple weeks, mine has acted funny a couple times, but the temps and weather have been doing some crazy stupid stuff all over the place. The only time I worry about it is when its actually cold and there is no reason for it not to work but it doesn't kick on.
Yeah my truck does that too.. Will idle normal at cold startup but then if I take a short drive and park again it will idle up for a few seconds sometimes.
Sent from my SM-G977U using Tapatalk
Sounds like really odd behavior.
Here's a video and a description on high idle.
My experience is that it will never kick on above 32 degrees or so, and for sure not when the ECT is already 140+
That's normal. Example of this, my LMM will idle up when I get 2 miles down to my coffee stop on a regular basis after doing a full elevated cycle at home. Totally normal.
