1 - 14 of 14 Posts
I need to change out the parking brake assembly so I need to remove the axle/hub. The manual calls for a
Axle Hub Nut Socket CH-49794. After looking for hours and hours the best I can find is a socket for sale for $135 ea (Im canadian so I'll end up paying over $200 plus shipping for one socket!).
Is there a universal socket that works? I can't imagine that every person who removed their rear hub over the last 9 years have all spent $135+ . I can't even find the socket at napa, mac, canadian tire, auto value etc. The nut is a 6 slot - I see lots of universal 6 pin axle nut sockets but none of them mention fitting 2011 GMC 2500 rear axle but list a whole ton of other compatible vehicles.
Many auto parts stores 'rent' these tools. You purchase a tool, use it for a couple of days, and return it and your money is refunded. See if your local stores have such an offer.
Unfortunately the two major parts stores I called wouldn't rent me tools - for covid-19 reasons they've suspended their rental programs. But they also didn't have that particular socket anyway.
Not that one. It's a 9 pin (which I believe is socket for truck newer than 2015)
But I found one similar on Amazon (it doesn't look exactly like the proper socket but for the price I might try it. The description doesn't include any newer models but it's the most common universal one I'm seeing. I can't find any info on dimensions for the actual retainer nut so not sure if a universal will fit.
https://www.amazon.com/ABN-Spindle-...K84CK9J0759&psc=1&refRID=2E8ME2C1NK84CK9J0759
Yup, hammer and punch. Get it done.
Fair enough. That's how trailer hubs are done. Tighten the nut just a bit until the wheel can't move than back it off.
I read somewhere (on this site I think) that hitting the proper torque was important- which is why I was searching out the socket.
Turns out that the axle nut is a 9 slot with 3 protruding pins/tabs. So realistically the correct socket probably looked like a 2&5/8" with three 3/8" notches cut into it. Or it may be machined perfectly to fit the 9 slots between the protruding pins and the axle. Who knows- pain in the ass!
It was sloppy but the 6pin socket that I mentioned above (from Amazon) worked. I was able to carefully hit the required torque to seat the seal/bearings with the help of a friend rotating the hub.
2012 3500 hd srw
Thanks for letting us know what worked. So many never post out come.
2006 Silverado 3500 6.6L LBZ SRW CrewCab Long box. Lots of Km.
think it's the same nut for 2006 lbz 14 bolts differential?
i just ordered it to try it out. garage just gave me an estimate of 2000+ CAD to fix the parking break on one side. screw that!. ugh...
I think it was around $12, whole rack of different ones at Advance Auto.
Yeah, that is the one I got from Advance also. It did the job but did not seat very well until I filed down some of the tabs to get it to fit right. No biggie, it did what I needed it to do. Dean
1 - 14 of 14 Posts
