1 - 7 of 7 Posts
I have had a small leak for a while but it's bugge me enough to where I wanna take care of it. It doesn't puddle under the truck, hell the pics I post are after I smear it so it's more visible. Extremely small but I want to fix it
Nonetheless less. Anyone can point me in the right direction please let
Me know! Thanks guys
Weird place for a leak. Looks like it could be welded.
That's what my buddy and I were talkin about doing. Didn't knownif there was any other way
If you didn't want to weld it, you could probably just clean it up real good with some brake cleaner and put some silicone on it. I personally would weld it and make it more permanent, but silicone will probably work for quite a while
If you wanted to weld it-- you would probably have to remove the rear axle-- dissamble the parts, pre-heat the cast iron and then weld it.
Lots of work for a small seeping of oil.
I would clean the area with a wire brush and carb cleaner-- paste a little JB Weld over the area and repaint.
Yes cast iron is tricky to weld altho it can be done it would be a long process all for that small or a leak. I agree with cleaning it really good and use some JB weld. If it was me thats what id do.
It shouldn't be cast, I welded the axle tubes on the Dana 80 in my cummins with a normal wire feed
Sent from my ADR6350 using AutoGuide App
1 - 7 of 7 Posts
