So I have noticed that the rear slider leaks when washing the truck or when it rains, it isn't a big leak or anything, but over time it has caused corrosion on the inside of the slider frame. My question is do you think the dealer would warranty this and replace it with a solid rear window? When I ordered my truck I wanted the solid rear window in the first place and with the Denali the slider was an option you could not remove anymore.
I think your warranty is long expired. Seal the leak or replace the window as you mentioned
'17 could still be under warranty.
Might be good to change the way signature is arranged so current ride is visible without needing to click the 'show full signature' hotspot.
