Aw come on...get your facts straight!There is no indicator showing if you are in regeneration mode on the pickup truck version Duramax. If a regen is in progress, it may continue while parked. If it needs to be initiated while extended parking, a message will show up on the DIC (it will not initiate if it is not already in progress while in park). You need to drive greater that 30 mpg for about 20 minutes. The owners manual explains this on pages 12, 23-24, 48 (for PTO operation). It states not to park over anything flamable. Hope this helps.
My truck goes into regen mode while idling, driving above or below 30mph or any other time it thinks it's time to. The time it stays in regen mode will depend on whether or not I'm idling or driving and how fast..Aw come on...get your facts straight!
An active regen will only take place while the vehicle is moving greater than 30 mph and will be stopped if the vehicle comes to a stop. The only indication that the vehicle was in regen will be a higher than normal idle speed (800 rpm)
If you do not drive the vehicle in the operating conditions for the ecm to initiate a regen, a message will come up on your DIC telling you to Clean Exhaust Filter. If you disregard the message, after a while your truck will go into reduced power mode and then the only thing you can do is go to the dealer to have a service regen done.
Like any vehicle, if you read the owners manual, it will tell you not to park over combustible materials.
How would I prove it? My Edge Attitude has a setting that tells me whenever is goes into regen mode. I even have it set to sound an alarm so I know. That, and watching my mpgs drop is all the proof I need. Feel free to go for a ride with me any time.prove it!
I have watched closely scan tool information ( lets just say I have acess to some pretty cool tools) on the LMM and have never seen one go into regen under 30 unless I have commanded one.
what is it baseing that information on ? EGT's or the fact that the ECM is commanding a regen.
Most likely EGTs and if that is the case, your edge is dumping enough fuel into the exhaust to raise the EGT of sensor 1 high enough to create a passive regeneration not an active regeneration.
So does this mean that you really don't need to worry about regen mode unless the DIC has a message saying to Clean Exhaust Filter? I have 500 miles on my truck and have no clue if it's gone into regen mode. Never seen a message. I don't drive very much highway so my gas mileage always sucks, lol.Aw come on...get your facts straight!
