36" X 1/2" (snapon SN36) breaker bar and some extra cheese burgers behind it. the breaker bar i used was almost an inch thick and it was not straight while pulling that bolt off.I have to replace the water pump and have to remove the harmonic balancer. I have already bent a 1/2 inch piece of steel. How do I get this off?
I used the AC pump to hold the breaker bar. I've since bought the tool. If the motor decides to start you'll have a serious problem on your hands.get a big cheater bat on a breaker bar, place cheater against the frame rail and hit the starter. watched it done a dozen times no issues
or buy the 20$ tool to do it right and run 0 risk of causing catastrophic damage to your engineget a big cheater bat on a breaker bar, place cheater against the frame rail and hit the starter. watched it done a dozen times no issues
Like what? It'll back the bolt out for you. For the record did mine last nov. Using exact method and it won't start unless you crank it over and tightening was a breeze with a hammer and breaker bar, did I get 300ft lbs? Prolly not but the bolt is still tight and a water pump takes less then 2 hrsI used the AC pump to hold the breaker bar. I've since bought the tool. If the motor decides to start you'll have a serious problem on your hands.
not everyone goes by the "gud 'nough" policy.... some people actually care if there balancer falls off half way down the highway. i doubt you came even close to 300 ft pounds with that method. probably didnt put locktight on either did ya. oh well, good enough.... probably dumped the old coolant back in too.Like what? It'll back the bolt out for you. For the record did mine last nov. Using exact method and it won't start unless you crank it over and tightening was a breeze with a hammer and breaker bar, did I get 300ft lbs? Prolly not but the bolt is still tight and a water pump takes less then 2 hrs
Actually no I used fresh coolant and did the T stats as well, and lock tite is mandatory, ya I'll loose a lot of sleep over whether a 8lb sledge had enough persuasion to tighten that boltnot everyone goes by the "gud 'nough" policy.... some people actually care if there balancer falls off half way down the highway. i doubt you came even close to 300 ft pounds with that method. probably didnt put locktight on either did ya. oh well, good enough.... probably dumped the old coolant back in too.
Just because you buy the $20 tool doesn't mean there is less risk of catastrophic engine damage. I've seem more damage using the tool than not. Most of the time because you are loading the torque to the bolt slowly by the time your bar and pipe bend and twist it will break the entire snout off the crankshaft. I have done it several times and seen it done quite a few times. But I have yet to see it happen using the starter. It shocks the bolt loose quicker I think. Can't explain it. But that's what I have found. Also almost forgot to mention. Use as short an extension or socket as you can so your right up against the balancer with your breaker bar.or buy the 20$ tool to do it right and run 0 risk of causing catastrophic damage to your engine![]()
I've wondered about this and the frequency of crank shafts snapping. I'm curious how many of the vehicles that had the crank snap had it happen some time after a water pump replacement, and if they did the flywheel tool or the starter method.Most of the time because you are loading the torque to the bolt slowly by the time your bar and pipe bend and twist it will break the entire snout off the crankshaft.
