Reprogramming default tire pressure in 2021 3500 HD
1 reading
28K views 58 replies 21 participants last post by  HawkScot
Hi all,
I know there are numerous threads on tire pressure, so I don't necessarily want to debate tire pressure here. Here's what I'd like to do.
1) Reduce my tire pressure when I'm not hauling load, which is 95% of my driving time for ride comfort
2) Get rid of the TPMS nagging display when doing so.
My plan is the following.
1) Decrease my front pressure to 50 PSI, Decrease my rear pressure to 45 PSI
2) Start the TPMS re-learn procedure from my steering wheel
3) Use this sensor tool to reset the sensors
What's not clear to me, is if this will also reset the pressure the system determines to be the default? On my 2016 Tundra, when you'd re-learn the sensors, it would also set the baseline pressure to the value currently reported by the sensor. I'd like this behavior on my truck so that my fronts are at 50 and my rears are at 45 as a baseline. While the warning doesn't bother me, I don't want my wife to have to worry about it when she drives the truck. I'm just not sure if the re-program will accomplish that. Has anyone tried this before?
Thanks!
Todd
@tnine , as already mentioned, what you're proposing will not change the pressures that the system alerts at.
Head to the dealer and ask very nicely, be prepared to also pay a nominal fee. Some dealerships will do it for free, some want to charge a $100 or so diagnostic fee. Some dealerships won't do it at all even if you want to pay for it. In fact, GM corporate even sent a memo to the dealerships to not adjust the alert pressures.
Sorry for the ambiguity, but it's the reality of the situation.
Both my local GMC and Chevy dealership told me "GMC has removed our ability to set that in the latest software release". I have no idea if this is actually true, or just what I'm being told so I go away. Does anyone know of any products I could purchase that I can do myself? I'm willing to spend some money on a piece of software and hardware to accomplish this, but I don't want to spend 1k upfront, then $500 a year just to get rid of a warning light, it's just not worth it. I flashed my old Tundra several times, so I'm pretty comfortable with the process assuming I get a decent quality programmer.
@tnine ,
This is well above and beyond just the tire thing, but there's lots of cool little options. My autosync is on its way....
I'll try to get you an answer. I think it should allow adjustment. Yea, I wouldn't want to disable it either.
@tnine , you'll have to get a hold of both vendors though and verify they support the 2021+ trucks.
Oh, and you buy the autosync first, then you buy the custom BCM programming from White Auto AFTER you receive your autosync.
#14 ·
@smeezy Where did you get that TPMS info? When I look at the description on the page @viper8315 sent, it only states
  • TPMS Disable / Enable – Allows for TPMS to be removed from your vehicle OR added (which will require custom cluster programming to display tire pressures) WE ARE NOT LIABLE FOR ANY DAMAGES ARISING FROM REMOVAL OF THE TPMS SYSTEM.
I've programmed my Toyotas for years but being new to owning a GMC I have to re-learn everything. Thanks for all the help guys!
#19 ·
Yes, I did. I haven't adjusted the tire pressures yet, but I saw the option to do it on the autosync.
A very important note here. From my understanding, for the 17-19 trucks you can adjust the pressures with the autosync, or disable the system completely if you also purchase the BCM tuning from WAMS.
It seems like for the 20+ trucks there's only the option to disable TPMS with the full BCM programming.
Please do your own research and verify your application and needs/wants for your truck.
#21 ·
For what’s worth… I just picked up a 2022 3500 DRW… I have an Autel TS508 that will change the pressure alert setting, but not on the 22… in the Autel I selected a 2021 SRW and successfully changed the pressure setting… set mine to 65 from the original 80, also the myChevrolet app updated the pressure after about a day…
#29 ·
interesting find yesterday. '
so I had a shop attempt to reprogram the thresholds nearly 2 weeks ago. they said they could do it no problem.
they were using an autel scan tool, a big ipad looking one with wireless obd port connectivity.
the tech did the programming, but it didn't work. the rears still showed low, then he went to relearn all of the sensors and they all went blank. we thought they would reset after driving a bit, but they did not. the tech was busy with another job, so they asked for me to come back. work has gotten in the way, so i haven't been back yet.
in the mean time, i relearned the sensors with the cheap amazon tool i have. everything is fine, but the rears are still showing low.
so i have been reading about the autel programmers and all the different functions of each. it seems like the one the shop tech was using was one that has all the features. so it should have worked. but i also noticed that all codes and lights had to be clear before programming. so maybe this is why it didn't work. 🤷🏻‍♂️
I placed an order for the Autel TS508, it says it can reprogram for tire load index. should work, just waiting for it to arrive.
Here is the interesting find: on my chevy app and on my chevrolet.com, both show the recommended front tire pressures for my truck as 50 psi. 🤷🏻‍♂️ I know for a fact the recommended pressure is set at 60 from the factory, I have a 3500. it has always showed 60 until just recently. the app still shows the rear recommended as 80.
so this tells me the shops programming took affect for the front, but not the rear. I wonder why? I wonder if there was a step missed?
I am debating whether to go back to the shop tomorrow and have them reattempt to program, or just wait until the ordered unit arrives and try myself.
it the shop can do it, i can return the order...
what to do...
#31 ·
what to do...
Sounds like the shop missed something, I attached a screenshot from the Chevy app, my tires were originally all set to 80psi..
#30 ·
Well, buying more tools is never a bad thing. If the scanner you bought is a full two way then you can perform some of the advanced relearn tests like on the NOX sensors should you ever have to replace them.
You know the old saying...if you want something done right, you have to do it yourself.
Not trying to slam your shop, just saying that you'll keep at it until it's right.
#32 ·
so i just got the tool.
decided to just go ahead and use it.
it took quite a while to register it and update it with the latest software.
took it out to the truck and hooked it up. went through all the proper selections. even selected 2022 model. everything populated the way it seems it should.
the tire pressures were indeed set to 50 psi front and 80 psi rear. this confirms the shop did not set the rears.
i reprogrammed the thresholds and confirmed. i disconnected the tool, gave it a few minutes, and then rechecked.
the programmed values were where i programmed them.
i am pretty sure it worked. now I will just have to drive around, then wait and see if the app and mychevrolet show the new programmed thresholds.
if it worked, it took longer to register and update the tool than it did to actually reprogram the truck
#33 ·
It will work just fine if your DIC shows it correctly, sometimes it takes the app 24 hours to update it, no idea why.
I went a different route since I already have an OBDLink MX+ dongle, got the Gretio app (iirc, that's @Snipesy 's app) and reprogrammed the sensors for my '22, was quite simple and pretty quick to do, but you do need to be a little bit of a computer techie geek to understand how to change the psi. The Chevy app updated the pressure settings within an hour or two iirc and I've had zero issues with it being like this, including a visit to the dealership who did an update to the truck.
#35 ·
Thanks for the feedback. I will be going this route with the TS508.
owns 2022 Chevrolet 2500HD LTZ Z71 Sport Edition
