1 - 2 of 2 Posts
So I put LED bulbs in my tail lights to replace the factory bulbs and I've got the resistors. I've tried nearly every combination I can with the resistors and I still have the hyperflash going on.
Has anyone successfully done this to get rid of the hyperflashing?
How are you installing the resistor? You need to mount it across the positive and negative wires. Also, what size resistors do you have? You need 3 ohms per bulb. I got mine here for my front turn signal bulbs.
1 - 2 of 2 Posts
