2003 eclb lb7 5 inch exaust ppei custom dsp5 tunes wc fab intake and charge pipes
I need help I sprayed some on the rubberized coating shit on my frame near the weel wells, went for a ride come back and there's a good amount of overspray on the panel between the rear bumper and tires so I wiped it off comes right off like thin rubber not stuck to paint or anything. Long story short it's been 4 months and it keeps comming back I can clean it go for a ride Ans it's back I power washed the frame anyti g underneath I could of got overspray on. Please help it's driving me crazy
Slave to the Interwebs
Sounds like it may just be something off the road. The coating should be more than dry
Agreed. Sounds like something on the road. Try mud flaps.
That's what I thought the first time but it's definitely the rubber overspray I tried everything power wash the whole undercarriage cleaned the overspray with lacquer thinner and then polished the truck with a weel went for a short ride come back same shit overspray all over the rear panels I don't know what to do about to find a new bed
Have mud flaps and it's never happend only after I sprayed the rubber frame coat. Never use that stuff it was rust oleum brand too
Did you spray this coating into the holes in the frame? Hard to really understand just what is happening. I don't know why spraying your frame would allow the material to be splashed by your tires. In any case, one solution would be to equip your truck with new wheelhouses - plastic wheel well liners. That should keep anything in the wheel well inside and not affected by the tires.
