Edit: One problem fixed, new major one!Right side flashers & p0540 code help!
Hi everyone,
Please see down for new problem!
New to the forum, been trolling for a while, you guys were a huge help recently with an Egr problem I had. Awesome site! :rockin
I'll start off with my infos:
2007 classic 2500hd
6.6 lbz
crewcab 4 x 4
70,000 kms.
K so here is my problem,
Was installing my new egr valve today and as i was putting the top end back together i accidentally touched the power cable that goes to the air intake heater relay to metal and i believe i blew the 175 amp mega fuse. the wire no longer has any power to it. After I finished putting everything back together I hooked up the scanner and got code p0540. Now I'm sure it's just that i blew the fuse, however i cannot find the relay or fuse anywhere. Anyone have any ideas were it might be, and how hard it is to change?
Truck seemed to run just fine, but I am getting a CEL on the dash.
Also, My entire right side of the truck, The flashers work "sometimes" They always work on the left side, but more often then not the front, rear and mirror right will not work. Sometimes it'll work once or twice, then will just stop. I thought it might be my switch, but i brought it to my mecanic and he said the switch was fine. also, when I have my trailer hooked up the lights always work on the trailer, but not on the truck, inside the truck the right flasher flashes fast like a bulb is burnt out (only when a trailer is hooked up, when its not, nothing comes up on the dash)...... Anyone have any ideas, I'm an electrical 0!
Thanks in advance!
Hi everyone,
2007 classic 2500hd
6.6 lbz
crewcab 4 x 4
70,000 kms.
Thanks in advance!
