1 - 2 of 2 Posts
Just got everything buttoned up and the truck was running fine after it started. Pulled out to test drive and it goes into limp mode, wont accept more than 1/4 throttle and idles rough. Has a check wallet light, gonna go get a scan tool. Last one went with the last car. I also replaced the fuel filter and started after I primed it the right way. Im sure this is a common problem to first time Dmax owners that DIY. Any input as to why this started after I put some load on the engine would be good. Thanks!
Discussion Starter · #2 · (Edited)
Well heres a shopping list of codes...
I started to laugh a little after 3 codes
p0193 - fuel rail press sensor circ high
p0098 - intake air temp sensor 2 circ high
p0107 - map sensor / baro circuit low... which is it?
p0405 - EGR sensor A circuit low
u0106 - GPCM lost comm
p0113 - intake air temp circ high input
p0183 - fuel temp sensor circuit high input
p2564 - turbo boost control position sensor circ low voltage
p0090 - fuel press regulator 1 control circ
p0193 - not sure why this one came back
I know some of these are because I forgot to plug the MAF back in after I took the airbox off to do something.
1 - 2 of 2 Posts
