1 - 20 of 28 Posts
This friday is the last night of racing in topeka kansas for the year for test and tune and it will be the first time runnin this truck the tranny is built but are you guys runnin in tow/haul or not.
i believe the t/c will lock up in either mode once the throttle is @ 100%. i dont think it matters which mode you use :gearjamin
Not according to my CTS it doesn't.
In tow/haul it will shift much faster and lock the converter starting in 2nd gear. I would suggest you use it.
it's called tow/haul ass mode for a reason
use it.
From what I've observed on my CTS, from a dead stop @ WOT, w/o T/H mode, the Transmission will lock the TCC starting in 2nd gear. Tow/Haul does seem to be a faster shift yet though, as I believe it raises line pressure.
I'd do it still, no harm.
Its just a worktruck
False. Line pressure drops ~100 psi when the TCC locks. If you dont have a built transmission with the internal pump mods using tow/haul for anything but towing or hauling is pointless and is doing harm to the transmission.
so you are saying locked converter is bad for stock(ish) transmission?
With the power turned up far beyond stock levels, yes.
First I've ever heard of that. What's your source?
Mike L.
T/H does nothing more than extend shift points so that your truck will get a better running start between gears under load. T/H locks the converter clutch in second gear to cool the trans and let the turbo pick up the load instead of the converter mutiplying uneeded tq. T/H also drops trans psi by 100 psi so you just lost holding power to your clutches. T/H works great as a grade break because it keeps the converter clutch locked during down shifts and that allows engine braking. It is not a magic pill. It is good for towing heavy loads and keeping your trans cooler.
I run in tow haul and I noticed it drops my ET by 0.2 comapred to not running in tow haul. I also just had my TCM reprogrammed to shift a higher RPMs when in tow haul because it seemed to shift too soon before. just my 2cents
Shit! Every time i get on it in my truck i put in in T/H.... better stop haha or trans will come sooner than i want it too. Why does it feel so much faster in T/H? Because its slipping the converter that bad in regular??
Weird, my times are always better in T/H...
stock turbo vs aftermarket. you dont want your TC to lock till you are on top of the charger and boosted. with a stocker it doesnt matter. but with a larger turbo, you can lose alot of power letting the truck lock up before your charger is spooled
Mike L.
Where in there does it say anything about harming the transmission by using T/H while not towing?
Chris is right. Pressure drops when the converter locks.
Sent from my phone, probably while driving and eating a sammich
it doesnt directly state damage will be caused...but when the TC locks the pressure does drop. thats less pressure to apply the clutches. less pressure holding the clutches = better chance of slipping the trans. it wouldnt be a problem in a STOCK tuned truck. but when you start testing the limits of a stock tranny, it matters
1 - 20 of 28 Posts
