Yep, pretty easy since they're LED lights on the mirrors. Connect the led's to each side of your mirrors so they are working correctly, then take a feed from your parking lights to each mirror. Connect the two +12vdc wires (parking and turn signal) together, then split the turn signal wire behind that connection (so its before the connection, closer to the vehicle and not closer to the mirror), install a 1n5400 diode or similar size/rating so that the silver line on the diode faces the mirror. Something like this:
Don't forget, you'll need to do the same thing on the left mirror, so at least 4 diodes will be needed.
EDIT: had to update diodes direction! When I duplicated it, it flipped it 180º! Image should now be correct with both diodes pointing the same way.
