1 - 20 of 22 Posts
My 1st winter with my lly. During summer it always ran 187-190 on cts. Now it will climb to 170-172 then drop back to 165-168 around town. So cold engine protection always on and fuel mileage is about 13mpg. Should I put a winter front on? Or replace thermostats? No other issues
Discussion Starter · #2 ·
Located in Massachusetts. So hasn't been that cold yet.
I put my winterfront on around freezing temps. If towing I keep an eye on the temp gauge. If you Don't know how old the coolant is you may as well change it and install new t-stats st the same time.
Thermostats. I went through two NH winters with the same issue. Changed out the stats, back to 181-183°
I was also running the gm grill cover before stats, now I'm not
Thanks I will replace them
I would also suggest sticking with the stock temp 180/185 stats, the factory ones made in Japan. I know there are different temps to choose from
Mine was running 179-189 today in 45°f
thanks! t-stats changed and temps back to 179-185 in in cold temps.
Good to hear
My truck runs 150F-160F while in the 30s.
I couldn't get my temp over 170 in the middle of the day here in the south a few weeks ago, it was normally 160; changed my tstats with GM stats and its running 180-189*
160 is fine.
It's supposed to run around 180. Probably another old thermostat issue.
P0128 copied from another site:
This means that the engine's PCM detected that the engine has not reached the required temperature level within a specified amount of time after starting the engine. The intent of the P0128 code is to indicate a faulty thermostat.
Read more at: http://www.obd-codes.com/p0128
Copyright © OBD-Codes.com
How you can say '160 sure that's fine' is beyond me. That's like yah the ecm is just lying to you, no prob
Furthermore up here where the temps get below freezing and even below 0, we need heat, and the engine needs to be at a proper temp to run it's best. Probably not as much of an issue in Texas
Mine runs around 160 in the winter due to short driving and have never had a CEL as a result. The engine would likely have to run a lot lower than 160 to trigger the fault. I understand your concern about heat, but the engine will be fine at 160.
People never realized their vehicles had so many problems before internet forums!
Discussion Starter · #20 ·
also if your running that cool the engine is super inefficient and burning a ton of fuel.its bad all around. makes no sense to not fix.its simple and cheap.i was getting 11-12 mpg running at 165 deg.
1 - 20 of 22 Posts
